Why there is an Oblique shock inside the Cd nozzle for the ideal flow condition?
Old   May 14, 2020, 05:39
Default Why there is an Oblique shock inside the Cd nozzle for the ideal flow condition?
Nirmal
snirmal30 is on a distinguished road
Using the Area ratio (A/A*) and for the desired exit Mach number I have designed a cd nozzle. The Inlet total pressure (Po) and the total temperature (To) is calculated using Isentropic relations for the optimum condition.
Nozzle divergence angle: 6 degree
Mesh Orthogonal Quality:
Nodes: 51660
Min: 0.9724
Max: 1
Average: 0.997
CONDITIONS:
Solver type: Density-based, Absolute, 2d, Axisymmetric
Model: Energy On, Inviscid
Material: Air (Ideal gas)
Boundary condition:
Inlet- Pressure inlet- 792812.3356 Pa; Supersonic/Initial Gauge pressure: 700000 Pa; Total Temperature: 518.4 K
Outlet- Pressure outlet- 101325 Pa; Backflow total temperature: 288 K
Operating condition- 0 Pa
Wall- Wall
For this condition, I should get an ideal flow throughout the nozzle, but there's an oblique shock inside the cd nozzle. Is this a design flaw or any error in the conditions?
snirmal30 is offline   Reply With Quote
Old   May 14, 2020, 08:20
Default Shock
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Mach number is not a good indicator of shock. Use static pressure plot to identify the shock. In Mach contours, even shear layers appear as shock.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
ansys, cd nozzle, ideal flow, oblique shock
Boundary conditions for flow in nozzle kgevers FLUENT 0 July 26, 2015 13:46
Simulation of a Multiphase flow in a Convergent-Divergent Nozzle RR16988 FLUENT 1 June 9, 2015 07:10
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
