How to plot contour of turbulence intensity in one direction in Fluent |
May 12, 2020, 23:16 |
pan-tzu-hao
I have simulated airflow over a bluff body three-dimensionally by ANSYS FLUENT. I would like to show turbulence intensity in CFD-POST.Although I could find it in the variable lists, but I just want to plot contour of turbulence intensity in x direction.
May 13, 2020, 01:54 |
#2 | |
Rep Power: 7 |
Turbulent intensity is a parameter that is defined in a way that it takes velocity fluctuations and mean velocity of all the three directions into consideration. Now I am supposing that your question is as follows: 1. either you want to calculate the turbulent intensity in the x direction only and plot the contour Well then you will probably have to define a custom parameter and try to do it. you can try to define the velocity fluctuations in the following way fluctuation(velocity in x direction) = (du/dx)*dx (where dx is the cell width in x direction) as so on for other directions. As for the mean velocity, refer these threads calculate mean velocity components in all cells after some time steps or Calculating mean velocity in each cell I think you'd be better served making a UDF for this. NonStopEagle |
May 13, 2020, 03:26 |
Isotropic Turbulence
EVM models, such as, and are called Isotropic turbulence models, i.e., there is an assumption of turbulence intensity being equal in all directions. So, TI is no longer a vector; there is no x-component. If you want that, you have to use RSM or Scale Resolving Simulations, such as, LES.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Turbulence Intensity underestimated | mr.adili | FLUENT | 7 | August 24, 2018 04:51 |
Turbulence intensity missing!! | Martin1 | FLUENT | 4 | May 6, 2017 17:26 |
Turbulence intensity plummets | Piedrapablo | FLUENT | 1 | February 5, 2017 23:28 |
Loss of Contour Plot colour intensity | Bou | Siemens | 3 | June 13, 2007 20:19 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
