May 12, 2020, 18:51 |
Autosave countours plot
Gabriel
Good evening,
I have more than 60 cases data simulated with fluent, and I would you like to read a case-data, update the 3 countours plot I have on screen than save them to file. Is this possible? Better via journal file or execute commands? Looking at the manuals I can only see TUI-commands to generate standard countors, but I would like to use the ones I have more costumized. Thanks, any help is appreciated! |
May 13, 2020, 09:07 |
Customization
What do you mean by customized contours? Are you using different views or colormaps, etc? You can set all those using TUI commands. As far as running it for 60 cases is concerned, use scheme loop as given in
Fluent setup
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
XY plot is not showing the surfaces I need to plot for. | rnb13143 | FLUENT | 0 | April 4, 2017 10:09 |
[swak4Foam] Foam warnings - related to swak4Foam | Salam-H | OpenFOAM Community Contributions | 20 | August 2, 2015 15:40 |
autosave output of x-y plot for unsteady case | Eric | Siemens | 3 | August 10, 2008 03:35 |
graph plot | anindya | Main CFD Forum | 2 | September 17, 2003 12:00 |
How to plot black countours | sachin pande | Siemens | 1 | October 11, 2002 06:57 |
