May 12, 2020, 14:34 |
Transient Heat Transfer
Annon
Rep Power: 16 |
Post deleted
May 12, 2020, 15:51 |
Clarity
The description you provided is ambiguous. You mentioned velocity inlet and pressure outlet no ambient air velocity. What does that mean? It appears you do not have any fluid domain in your simulation. There are only solid domains. Or do you have a fluid domain as well? If you have really applied velocity inlet and/or pressure outlet boundary conditions, then fluid domain exists since Fluent does not allow such boundary types for solid domain. But you need to provide some clarity, may be share some snapshots of the setup.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
problem in transient heat transfer of ground heat exchanger | teguhtf | FLUENT | 0 | April 23, 2020 05:46 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
help on a convective heat transfer transient model | cmbv | FLUENT | 0 | December 14, 2007 17:16 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
time steps in transient heat transfer in solids | Mike | Main CFD Forum | 3 | June 5, 2003 05:47 |
