Export profil every time step
Like Tree6Likes
Old   June 9, 2020, 06:14
Hassan
hassanayaz is on a distinguished road
i have used non-conformal periodic zone for 3D geometry..... when i do initialization first time after creating non-conformal periodic zones then no error shown in console but when do re-initialization then the following error shown.... same for other two boundaries
Error: Non-conformal periodic interface inlet-outlet with empty intersection.
This is likely due to incorrect specification of periodic
offset values. Please check the offset values specified
and recreate the interface.
what could be the problem?????????
hassanayaz is offline   Reply With Quote
Old   October 20, 2022, 14:43
Default problem reading profiles
  #42
alejandro alonzo garcia
alejandro_1980 is on a distinguished road
Send a message via MSN to alejandro_1980
Originally Posted by vinerm View Post
%t and %i can be used for writing but not for reading a file. You have to use scheme command to read those files.
(ti-menu-load-string (format #f "file read-profile name_~04d.prof" (rpgetvar 'time-step)))
where you need to replace name_ with actual basename. 04 specifies number of 0s before value at the end. So, if the file name is name_0003.prof, then the command above will read it. If it is 00003, then use 05 in place of 04.
Dear Vinem, how can i read profiles named run0001.prof, run0002.prof and so on? May you provide me the modification to your previous entry?
alejandro_1980 is offline   Reply With Quote
Old   December 13, 2024, 21:46
Ayobami
Ayo10 is on a distinguished road
Hello, so I am simulating a flow in a box flowing around a heater at the center in 3d. I want to have a circular ring having six sensors sitting some distance above the heater, another ring with six sensors at the mid-point of the heater and the third ring with six sensors below the heater. Please how can I develop this and pull out my data from each of these rings and sensors with respect to time. Thank you
Ayo10 is offline   Reply With Quote
boundary condition, every time step, export profil
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
