Who can tell me is there sth wrong in my settings of frame motion model? |
May 11, 2020, 05:18 |
Alex
Rep Power: 6 |
I did a centrifugal pump's simulation which was shown in fig1(the vilocity streamlines in CFD-post),but I don't know why the vilocity streamlines looks like wrong(blue circle).
The point O's coordinate is(0,0). Is there sth wrong in my settings of frame motion model? Maybe I should get the "R" bigger? I attached the cas file on my thread.Thank you in advance. |
May 11, 2020, 05:27 |
Alex
Rep Power: 6 |
Or I should use sliding mesh model to do this simulation:
https://ansyshelp.ansys.com/account/..._slide_ex.html |
May 11, 2020, 12:04 |
Frame of Reference
Most likely you are plotting the velocity profile using rotating frame of reference. In CFDPost, you need to select stationary reference frame.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 11, 2020, 23:37 |
Alex
Rep Power: 6 |
Thank you!
I saw the pathlines in fluent,almost like the CFD-post's steamlines.(fig1) And would you please tell me how to select stationary reference frame in CFD-post? I didn't found the options in CFD-post(fig2, fig3) |
May 12, 2020, 00:22 |
Alex
Rep Power: 6 |
and the vilocity vector map is quite continuous.
Maybe I didn't understand what pathlines means?or the pathlines are not suitable for frame motion model? |
May 12, 2020, 00:40 |
Alex
Rep Power: 6 |
May 12, 2020, 08:32 |
Pathlines
Pathlines are particle tracks with particles being massless, implying, pathlines show paths taken by the continuous fluid.
May 12, 2020, 22:04 |
Alex
Rep Power: 6 |
May 13, 2020, 10:02 |
Reference Frame
#9 |
Are you plotting the pathlines or velocity contour using stationary frame or rotating frame?
May 13, 2020, 21:53 |
#10 |
Alex
Rep Power: 6 |
May 14, 2020, 08:42 |
CFDPost
#11 |
There are two variables listed as Velocity in CFDPost, namely, Velocity and Velocity in Stn Frame, i.e., Velocity in stationary or inertial frame. Default is Velocity and not Velocity in Stn Frame. But we are not used to looking at the flow from rotating frame; it looks strange. So, choose Velocity in Stn Frame and then display.
May 15, 2020, 01:06 |
#12 | |
Alex
Rep Power: 6 |
Thank you,Vinerm.
It seems like more reasonable when I change to variable from velocity(1st way) to "velocity in Stn Frame"(2nd way). The word "Stn" means stationary?So what way show the absolute motion trail? the 1st way or the 2nd way? And I also wonder why the pathlines are not continuous neither start from Locations nor face centers and so on. Is there sth that I can do to improve it? Best Regards! Quote:
frame motion |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
udf error | srihari | FLUENT | 1 | October 31, 2016 15:18 |
Option Frame Motion | AP3181 | Main CFD Forum | 0 | November 12, 2015 11:17 |
incompatibility of frame motion with energy equation activation ? | Rockda | FLUENT | 1 | April 3, 2012 09:35 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 10:02 |
