How to set mesh conditions for propeller simulation?
Old   May 10, 2020, 00:31
Default How to set mesh conditions for propeller simulation?
Alex
cfd2020 is on a distinguished road
Hi, I'm learning to do some propeller simulation which was shown in fig1,A is one point on the propeller,so when the propeller rotate like fig1,the point A has a relative velocity to water ,this velocity was divide into V1 & V2.
I try to use frame motion treat this simulation, but I have sth comfused:
1,like fig2, how fluent get V2?compute from the rotational motion speed 1280rpm and the density of the water?
2,If I set the frame motion like fig2,it means that the water around the propeller move togetther with the propeller ,that means V2=0, but I think it's inconsistent with the actual situation.Because in actual situation V2 is not zero, so how can I get the realistic simulation?
Thanks in advance,Regards!
cfd2020 is offline   Reply With Quote
Old   May 10, 2020, 16:47
Default Frame Motion
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Frame motion model is based on the assumption that the flow is statistically steady, implying the flow around the impeller is running almost at impeller velocity. When Frame Motion model is used, Fluent determines Coriolis and centrifugal forces that are based on user specified speed, density of fluid, and radial coordinate and volume of each cell in the rotating zone. These are applied as momentum source terms and fluid flow is evolved. So, don't worry. You will observe expected v2.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 11, 2020, 04:48
Alex
Thank you very much,I will try
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 06:28
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Trying to set up Moving Mesh Problem dreamchaser CFX 5 December 15, 2014 01:07
Problem w/ vortex ring simulation, mesh coarseness parameters? ESC FLUENT 2 September 4, 2012 11:56
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
