How to get good initialization in parameter simulation?
Old   May 9, 2020, 12:33
Default How to get good initialization in parameter simulation?
Alex
cfd2020 is on a distinguished road
I have several design points parameter simulation to do.
I do the initialization by the way of 'hybrid+patch', and get the design point0's results successful.But the fluent can't get the design point1's result(floating problem,compute divergence,and so on).
So how can I tell the fluent initialize like my way(the ‘hybrid+patch’ way before) before it compute the design point1?use UDF? thanks in advance!
cfd2020 is offline   Reply With Quote
Old   May 9, 2020, 17:28
Default Parametric Simulation
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Better do it outside WB. Standalone Fluent gives provides more flexibility and user control. Within WB, it is controlled by WB. To do automatic parametric simulation in stand-alone Fluent, you can make use of Fluent journal commands.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 9, 2020, 22:17
Alex
Thank you very much! Best Regards!
initialization, parameter simulation
Is Solidworks Flow Simulation Good? corriolisforce Main CFD Forum 4 October 22, 2018 12:44
Transient Simulation in CFX ashtonJ CFX 1 September 28, 2018 02:18
finite values inside the simulation domain with hybrid initialization at t =0 sgbaek FLUENT 0 February 15, 2018 19:45
IS Phoenics good for multiphase simulation zino Phoenics 1 April 30, 2011 20:38
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 17:29
