May 18, 2020, 12:59 |
#61 |
Siddharth Vohra
Rep Power: 6 |
The result is diverging.
I generated a tet mesh of about 4mil elements and converted it to polyhedral. |
May 18, 2020, 13:17 |
Mesh
#62 |
Use a coarse mesh in the beginning. I don't know the size of your domain but prefer to run with maximum 0.3 - 0.5 million cells as first case. Once you are satisfied with the result, then refine the mesh using adaptive refinement only in the regions of liquid lumps.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 18, 2020, 14:06 |
#63 |
Siddharth Vohra
Rep Power: 6 |
Tried with 0.5 mil elements, still diverging
May 18, 2020, 16:21 |
VoF-to-DPM
#64 |
Then there is some issue with the setup of VoF-to-DPM. You have to follow the procedure to setup VoF-to-DPM as per the user guide.
ansys, cfd, dpm, fluent, multiphase |
CaseSetup Nozzle Spray Pattern | Jikst | OpenFOAM | 15 | August 31, 2023 20:12 |
Help with modeling a spray from a nozzle | dmcguire123 | FLUENT | 2 | June 9, 2021 04:34 |
Can anyone suggest a good tutorial of Spray Combustion in Ansys FORTÉ? | shubhra | ANSYS | 2 | October 5, 2017 07:06 |
Star CCM+ Ad-blue spray | shihab2k9 | STAR-CCM+ | 1 | June 11, 2017 04:32 |
spray injection | mmacrb | FLUENT | 0 | January 10, 2007 05:57 |
