Spray pattern
Like Tree31Likes
Old   May 8, 2020, 06:47
Default Opening
  #21
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
All you need is a small patch on one of the sides. So, one side of the cylinder will be one big circular surface while the other side will have one small circular surface and one big annular surface around it. Small surface will be used as air inlet as well as same location will be used for injection. Do note that Orifice Atomizer requires coordinates and not surface.
Swish31 likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 9, 2020, 10:59
Siddharth Vohra
Swish31 is on a distinguished road
I ran it.
I can't see the results as i cannot click the pulse button in particle tracking. Looks like it is frozen. What to do?
Swish31 is offline   Reply With Quote
Old   May 9, 2020, 17:22
Default Pulse
  #23
vinerm's Avatar
Vinerm
You don't need to use Pulse for results. Run the simulation. While running, it should show a positive number of tracked particles. If it is 0 then there is problem with the injection setup. If it is there, then, go to Particle Tracks, Select Injection from the list, and then Display. No need to use Pulse.
Swish31 likes this.
Regards,
Vinerm
Old   May 10, 2020, 05:48
Siddharth Vohra
Particles tracked are not zero but i can't see their paths.
Seems like there are very few particles as well.
Old   May 11, 2020, 12:46
Default Particle Tracks
  #25
vinerm's Avatar
Vinerm
What does Fluent show in its text interface when you click on Display for Particle Tracks?
Swish31 likes this.
Regards,
Vinerm
Old   May 12, 2020, 05:12
Siddharth Vohra
After calculation is done and click on display in particle tracks, it shows this
Calculation complete.
number tracked = 42, escaped = 42, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0, incomplete_parallel = 0, shed = 0
DPM Iteration ....
Old   May 12, 2020, 10:17
  #27
vinerm's Avatar
Vinerm
Could you share a snapshot of Particle Tracks panel?
Swish31 likes this.
Regards,
Vinerm
Old   May 13, 2020, 08:30
Siddharth Vohra
Here sir, have a look at these images.
https://drive.google.com/open?id=11Z...SmSkruLlh0PRI3
Also i have set Dpm injections for an interval of 10 iterations. When i run the problem, the number tracked in DPM injections becomes zero after the first or first 2 injections.
Old   May 13, 2020, 08:42
Default Particle Display
  #29
vinerm's Avatar
Vinerm
Ah! That's because you have chosen point for Track Style. Change it to line or increase the size of the point. Currently, those might be too small to be visible.
Secondly, you have left stop time to 0. That means, injection happens only for the first time-step. Set it to a high value, say, 1000.
Swish31 likes this.
Regards,
Vinerm
Old   May 13, 2020, 10:49
Siddharth Vohra
There is no line option.
Only point and sphere.
I scaled the point to a larger size but still no good.
Could there be any problem with my injection?
Old   May 13, 2020, 11:03
Default Unsteady Tracking
  #31
vinerm's Avatar
Vinerm
That happens if you enable Unsteady Tracking. If you do that, you need to run the simulation for enough time to ensure that particles have traveled some distance into the domain. Only then you will be able to display particles. 42 should also be visible but either right at the injection location or at the outlet, depending upon what time-step you used.
Swish31 likes this.
Regards,
Vinerm
Old   May 13, 2020, 11:05
Siddharth Vohra
I let it run for a good 500 iterations and stop time as 100s.
Still it is not visible.
Old   May 13, 2020, 11:26
Default Iterations
  #33
vinerm's Avatar
Vinerm
Is your simulation steady-state or transient?
Swish31 likes this.
Regards,
Vinerm
Old   May 13, 2020, 11:27
Siddharth Vohra
It is steady state
Old   May 13, 2020, 11:47
Default Injection Time-Steps
  #35
vinerm's Avatar
Vinerm
Then, you need to ensure that there are enough time-steps given for particles. Since flow is steady-state, you need to specify total time-steps in DPM Panel under Unsteady Tracking. Default would be 1. Increase it such that particles are able to go from injection point to outlet in time determined using product of number of time-steps and time-step specified in DPM panel. For testing, just increase it to 100, run the simulation for 50 or so iterations, and then display tracks. Increase the point scale to 1 from default 0.1 under Particle Style.
Swish31 likes this.
Regards,
Vinerm
Old   May 13, 2020, 17:45
Siddharth Vohra
Dear sir,
i tried total number of steps from 100 to 500 and particle time step size from 0.001 to 0.0001.
Still no good.
Old   May 14, 2020, 04:38
Default Time-Steps
  #37
vinerm's Avatar
Vinerm
Do note that there are three parameters, Max. number of steps, Particle Time-Step Size, Number of Time-Steps. The last two are relevant for Unsteady Particle Tracking only. It appears you are changing only Max. number of steps. Those should be at least 500 for Unsteady Tracking. But you also need to increase Number of Time-Steps from 1 to higher value, say, 100.
Swish31 likes this.
Regards,
Vinerm
Old   May 14, 2020, 04:41
Siddharth Vohra
Sir i know.
I have set the maximum number of steps to 500 and then changed to 1000 as well in addition to the above mentioned changes.
Old   May 14, 2020, 05:38
Default Number of Tracked Particles
  #39
vinerm's Avatar
Vinerm
As you run the simulation, do you see an increase in the number of Tracked Particles? For the time being, disable Unsteady Particle Tracking.
Swish31 likes this.
Regards,
Vinerm
Old   May 14, 2020, 12:33
Siddharth Vohra
No sir, the number of tracked particles do not increase.
I disabled unsteady particle tracking and ran the problem. Now the particle tracks are visible nut however these particles are not travelling in the Y axis direction but rather are in the Z axis direction only.
I checked the boundary conditions, gravity and injection parameters. Everything is given with respect to Y axis only then why this?
https://drive.google.com/open?id=1LD...i607dges73vdc5
ansys, cfd, dpm, fluent, multiphase
CaseSetup Nozzle Spray Pattern Jikst OpenFOAM 15 August 31, 2023 20:12
Help with modeling a spray from a nozzle dmcguire123 FLUENT 2 June 9, 2021 04:34
Can anyone suggest a good tutorial of Spray Combustion in Ansys FORTÉ? shubhra ANSYS 2 October 5, 2017 07:06
Star CCM+ Ad-blue spray shihab2k9 STAR-CCM+ 1 June 11, 2017 04:32
spray injection mmacrb FLUENT 0 January 10, 2007 05:57
