What are these gas density options means?
Old   May 6, 2020, 03:43
Default What are these gas density options means?
Alex
cfd2020 is on a distinguished road
In materal database settings,for example:real-gas-Soave-Redlich-Kwong, real-gas-peng-Robinson etc.
Regards!
cfd2020 is offline   Reply With Quote
Old   May 6, 2020, 05:31
Default Real Gas
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
These are model to model density of real gases. In reality, every gas is a real gas, i.e., their density is defined by some function of temperature and pressure. Ideal case is governed by Ideal-Gas law and most of the gases do follow this law at low enough pressure and high temperature. But there are certain phenomena that exist because gases are not ideal, such as, isenthalpic process that change the temperature of the gas during expansion in refrigerator evaporators.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 6, 2020, 05:51
Alex
Thank you very much,regards!
density, material database
CFD Volume change via density to obtain temp profile (gas phase) ayaanin Main CFD Forum 0 January 26, 2016 12:22
Density and compressiblity Mohsin FLUENT 7 June 7, 2015 23:23
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 15:20
Mixing Plane + Ideal Gas Density (Compressible) = Tragedy kanduri FLUENT 1 June 25, 2011 18:24
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
