Post procession create circular surface contour around bend tube |
April 30, 2020, 18:37 |
OHMM
Hi I have tried to create the circular surface contour of fluid velocity but I can only create in the xz plane. I would like to get it in circular shape around the bending section. How I can achieve that
May 1, 2020, 15:38 |
Incomplete Information
I suppose a picture of the domain might make it easy to provide a solution. A bend could be of any type, however, if the bend is aligned with a plane, then all you need to do is create a plane or iso-surface. So, a picture would be useful.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Cannot Create Surface from sliding interface zone, Create empty surface | onn83 | FLUENT | 5 | June 28, 2024 11:14 |
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 09:26 |
how to create at circular surface in a flunet case for post processing | novic | FLUENT | 1 | December 25, 2016 23:19 |
how to create contour surface for some range | sa | CFX | 6 | January 28, 2009 14:36 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
