Inlet velocity issue in ansys (premixed combustion)
Old   April 30, 2020, 13:54
Default Inlet velocity issue in ansys (premixed combustion)
Koo How Boon
Kenzhia3310 is on a distinguished road
Hi, there.
In order to obtain a stable flame shape, the inlet velocity has to be always between laminar burning velocity and blow-off velocity.
But I am not sure the inlet velocity refer to the max or mean velocity in my parabolic diagram?
Can someone explain the theory as well?
Kenzhia3310 is offline   Reply With Quote
Old   April 30, 2020, 15:28
Default Inlet Velocity
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Velocity at the inlet is user specified. If you specify a constant value then the profile is a planar (straight line for 2D), i.e., no variation across the boundary. If you want to apply parabolic profile, then you have to apply it using a profile file or UDF. If you are using v19.x or later, you may use expressions as well.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Premixed combustion issue Kenzhia3310 ANSYS 0 March 27, 2020 04:40
UDF comilation error. urgent help please m zubair Fluent UDF and Scheme Programming 4 February 10, 2019 12:19
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
