gmsh file export unv to import by fluent
Old   April 29, 2020, 17:37
Question gmsh file export unv to import by fluent
maksay is on a distinguished road
I tried to make a cube and export the file from gmsh to unv to import it to Fluent. My code is as following:
//Points
Point(1) = {0, 0, 0, 1};
Point(2) = {1, 0, 0, 1};
Point(3) = {0, 1, 0, 1};
Point(4) = {1, 1, 0, 1};
Point(5) = {0, 0, 1, 1};
Point(6) = {1, 0, 1, 1};
Point(7) = {0, 1, 1, 1};
Point(8) = {1, 1, 1, 1};
//Lines
Line(1) = {1, 2};
Line(2) = {3, 4};
Line(3) = {1, 3};
Line(4) = {2, 4};
Line(5) = {5, 6};
Line(6) = {7, 8};
Line(7) = {5, 7};
Line(8) = {6, 8};
Line(9) = {1, 5};
Line(10) = {3, 7};
Line(11) = {2, 6};
Line(12) = {4, 8};
//Surfaces
Curve Loop(1) = {3, 2, -4, -1};
Plane Surface(1) ={1};
Curve Loop(2) = {7, 6, -8, -5};
Plane Surface(2) ={2};
Curve Loop(3) = {10, -7, -9, 3};
Plane Surface(3) ={3};
Curve Loop(4) = {12, -8, -11, 4};
Plane Surface(4) ={4};
Curve Loop(5) = {9, 5, -11, -1};
Plane Surface(5) ={5};
Curve Loop(6) = {10, 6, -12, -2};
Plane Surface(6) ={6};
//Transfinite Lines
Transfinite Curve {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12} = 21 Using Progression 1;
//Transfinite Surface
Transfinite Surface(1) = {1, 3, 4, 2};
Transfinite Surface(2) = {5, 7, 8, 6};
Transfinite Surface(3) = {3, 7, 5, 1};
Transfinite Surface(4) = {4, 8, 6, 2};
Transfinite Surface(5) = {1, 5, 6, 2};
Transfinite Surface(6) = {3, 7, 8, 4};//+
Recombine Surface {1, 2, 3, 4, 5, 6};
//Volumes
Surface Loop(1) = {1, 3, 6, 2, 4, 5};
Volume(1) = {1};
//Transfinite Volume
Transfinite Volume{1} = {1, 2, 4, 3, 5, 6, 8, 7};
Recombine Volume {1};
//Boundary Conditions
Physical Surface("Inlet-Air") ={3};
Physical Surface("Wall-adiabatic") ={1};
Physical Surface("Symm-side") ={2, 5, 6};
Physical Surface("Outlet") ={4};
Physical Volume("Fluid") ={1};
There are two issues related with this:
1. GMSH
If I choose to export also the elements it gives me 8 times the following error:
Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid
2. Fluent
Thus I don't export elements and I tried exporting the unv file with or without nodes. In both cases Fluent give me segmentation error and closes.
Is there any solution for this?
Thanks everyone for their help
maksay is offline   Reply With Quote
Old   April 30, 2020, 05:59
Default Universal Format
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
I don't think you can read universal format in Fluent, starting with version 6. Better to write in .msh format; gmsh can do that.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 30, 2020, 06:33
Unfortunately academic version of fluent does not accept msh files, thus I need to import .unv file
Old   April 30, 2020, 06:38
Default Fluent
vinerm's Avatar
Vinerm
There is no difference in academic or commercial version of Fluent. The code is same; it would not be justified to write a separate code for academia. It is only limited by its capability to work with larger meshes. But do note that .msh file that gmsh writes is different from .msh file that Fluent uses. You have to convert it to Fluent format.
Regards,
Vinerm
Old   July 31, 2024, 10:52
blacKened is on a distinguished road
I'm having the same problem importing a .msh file (2D) from gmsh into fluent. Are there any ways to convert it?
blacKened is offline   Reply With Quote
export, gmsh, import, segmentation error, unv
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
