April 24, 2020, 05:05 |
Problem with lift coefficient
Rep Power: 6 |
Good morning,
I'm doing a CFD analysis of Tesla cybertruck in 2d,I have the student edition of Ansys fluent,I did the mesh and refined with face sizing on the back of the car where there it starts the wake and used edge sizing and inflation to refine the mesh near the car.The problem is that when i run the calcul on FLUENT i have convergence but i get a CD of 0,25 and CL of 1,5( really big i think). I'm using k-omega with inlet velocity of 50 km/h,bottom inlet V=0 km/h ,pressure outlet, no slip conditions on the car walls and shear=0 on the top. As intensity i put 1 % and viscosity ratio 0.1.My professor suggested me to use these conditions but now is not answering me and i'm in the panic.For refernce values i took are =heigth of the car 1,49 m and width=2m,length=5,8m Thanks you |
April 24, 2020, 06:19 |
Coefficients
In Reference Values, you also need to provide density and velocity as per the free-stream. Furthermore, use larger values for intensity and viscosity ratio. Use 5% and 5 or 10. 1 is a the smallest value for viscosity ratio. Value below this does not have a relevance.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 24, 2020, 08:35 |
Rep Power: 6 |
I tried with bigger values of turbolence as you told me but keep giving me the same results
April 24, 2020, 08:41 |
Turbulence
Turbulence value at the inlet will not have a drastic effect. More important are reference values for the coefficients. Do note that reference values do not affect the solution. So, you don't need to rerun the simulation. Just change reference values for density and velocity and then determine the coefficients.
April 24, 2020, 08:52 |
#5 | |
Rep Power: 6 |
April 24, 2020, 09:00 |
Flow
Then you need to look at the setup. Are the boundary conditions correct? Is the mesh fine enough to resolve the boundary layer, since you are using ? And what do you mean by bottom inlet velocity?
April 24, 2020, 09:07 |
Rep Power: 6 |
I sent you a picture attached.For the top i put wall and shear stress=0,the walls of the cars i put no slip
April 24, 2020, 09:15 |
Bottom
Which boundary is bottom? Do you mean the ground? Ground must be no-slip wall.
April 24, 2020, 09:18 |
#9 |
Rep Power: 6 |
April 24, 2020, 09:49 |
Ground
#10 |
Ideally, since the reference of frame changes from inertial to vehicle, the ground should also be given a velocity towards the rear of the vehicle. And it has to be a moving wall at 13.89 m/s. However, this won't have much effect. So, you can either use no-slip wall or moving wall at 13.89 m/s in the opposite direction of vehicle's motion. But not a velocity inlet.
April 24, 2020, 10:55 |
#11 | |
Rep Power: 6 |
April 24, 2020, 11:02 |
Drag and Lift Coefficient
#12 |
I cannot comment on the values of drag and lift coefficient. Better to compare against some experimentally determined values for same or similar body.
April 24, 2020, 11:06 |
#13 |
Rep Power: 6 |
April 24, 2020, 11:16 |
Negative Coefficient
#14 |
For vehicles, it must be negative, else vehicles will fly-off the road. However, the negative or positive does not really matter here. Lift coefficient is not even calculated for road vehicles, only drag coefficient is determined.
April 24, 2020, 11:24 |
#15 |
Rep Power: 6 |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
Fluent 19.0 Lift and Drag Coefficient Monitors | TeriSerugi | FLUENT | 0 | February 6, 2019 17:21 |
Drag and Lift coefficient for diffusor | rego | STAR-CCM+ | 3 | May 7, 2012 18:05 |
Lift force coefficient for 2-phase flow | Summer | FLUENT | 0 | April 29, 2008 17:58 |
Lift force or coefficient of lift | Rola | FLUENT | 1 | November 12, 2006 13:29 |
