Amin
Rep Power: 0 ![]() |
I have a question regarding using overset interfaces along with overlapping (coinciding) walls in 3D. I’m trying to simulate the flow field around a rocket by importing three meshes (background mesh, payload fairing mesh, and the body mesh) into Fluent 19.2. When I create the overset interface between the fluid domain and overset components (fairing + body), I end up with thousands of orphan cells (fig. 1). I tried to import the oversets components separately (figs. 2 & 3) and it looks to work out without a single orphan cell. Also, “Display-cells” command remains invalid even after I mark the orphan cells in a register. This prevents me to visualize the orphan cells location. If I run the calculations anyway, Aerodynamic forces will remain zero for the whole calculations. Is there any missing treatment for the walls’ connection? Any help would be greatly appreciated! Best regards, Amin |
Nidhi
Rep Power: 8 ![]() |
Hello I am having a similar issue. Did you figure out how to solve this problem?
overlapping grid, overset fluent |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Overset MESH problem DFBI 6DOF | Ale85 | STAR-CCM+ | 0 | October 1, 2013 12:25 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
