DPM convergence and particle size
Old   April 23, 2020, 11:55
Default DPM convergence and particle size
CFDSim72
sirsammie72 is on a distinguished road
New to CFD:
I recently ran a simulation with 1um particles and converged fine. When I increased to 5 and 10 um the simulation no longer converges. I am wondering if Eulerian time steps should be changed with particle size, or DPM time step settings?
Or any thoughts on what is causing this?
I am using LES and DPM steady particle tracking.
Thank you
sirsammie72 is offline   Reply With Quote
Old   April 24, 2020, 09:48
Default Particle Size
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Since you are using LES, what is the mesh size that you have? 5 micron is not a very big size. What are the volume fraction and mass fraction values for the particles in the domain?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 24, 2020, 11:57
CFDSim72
Mesh size is 0.004m, not yet optimized or confirmed for independence. I think it may have to do with particle drag, and must switch to unsteady tracking and give separate particle time step
Old   April 24, 2020, 12:04
Default Mesh Size
vinerm's Avatar
Vinerm
What is the Re that you are trying to resolve? 4 mm is too large for LES. If there is no specific requirement to use LES, use RANS, i.e., k-\varepsilon or k-\omega. LES would require much finer mesh if you want to resolve, say, at least 92-95% of energy containing eddies. Determine your eddy length scale and then compare it against your mesh size.
Regards,
Vinerm
Old   May 13, 2020, 03:45
Anshuman Sinha
Anshs is on a distinguished road
But DPM requires mesh size to be greater than particle size.
And how to determine the eddy length scale?
Anshs is offline   Reply With Quote
Old   May 14, 2020, 08:58
Default DPM and Eddy Length Scale
vinerm's Avatar
Vinerm
Yes, it is required that particles should not occupy more than 10% of the volume, locally as well as globally for DPM to be valid. However, LES has its own mesh requirement. So, if your mesh is not fine enough, use RANS. If it is fine enough for LES but large enough for DPM, then it should not pose any challenge at all. Secondly, determine Stokes number value for particles that you are using. You may not even require two-way coupling for particles.
For length scales, you can have a look at
https://en.wikipedia.org/wiki/Taylor_microscale
Regards,
Vinerm
dpm, fluent, les
particles leave domain Steffen595 CFX 9 March 7, 2016 17:19
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 10:46
cfx particle convergence problem bharath CFX 0 November 11, 2009 09:34
Steady state DPM - Convergence and particle tracks Sandilya Garimella FLUENT 2 March 28, 2008 16:53
convergence in particle transport model Jose Tinoco CFX 0 March 3, 2003 04:10
