dhanik
Rep Power: 6 ![]() |
Good morning I am a beginner in CFD, I am using Ansys fluent, I have 2 inlets and 1 outlet condition (It is tee joint) I want to know as per boundary conditions name Inlet is considered as velocity inlet , but for outlet why it is considered as "pressure outlet"?
thank you |
The objective of CFD is to predict the fields, i.e., variation of pressure, velocity, etc. over the space and also over the time, if required. Velocity at the outlet is not known a priori; average velocity could be known but if the goal is to predict only average velocity, then CFD is not required. Usually, the variation in the velocity is required to be predicted at the outlet. Hence, velocity is unknown, however, the pressure may or may not be known. If a duct is open to the atmosphere, then the average gauge pressure is 0. So, pressure outlet is used most of the times. Sometimes, velocity or mass flow rate may be known. So, it is not that always pressure outlet is used at the outlet. It could be any of the boundary conditions; it all depends on the objective of the simulation and the available information.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
ansys |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 18, 2018 23:39 |
Pressure outlet BC help! | eishinsnsayshin | FLUENT | 7 | December 3, 2012 23:36 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 12:41 |
Help ASAP! pressure inlet & outlet | engahmed | FLUENT | 0 | June 13, 2010 15:33 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
