Grid Motion in Parallel
Old   April 21, 2020, 20:32
Default Grid Motion in Parallel
j
buckngnr11 is on a distinguished road
Hi, I'm having a small issue with my dynamic mesh UDF. I am running in parallel and end up doing some calculations to figure out how much to displace each wall vertex on my mesh. It seems to work fine except when I hit update dynamic mesh and run 1 iteration, it performs the grid motion twice. I also display a message for how much volume total I am displacing. When I hit update dynamic mesh, the message displays twice. The first tie it shows the correct volume to move the mesh. The second message shows exactly double the first volume. As shown, I use a += statement to loop through all the cells to get this value. This tells me that the entire thing is running twice for some reason. I'm running on 28 processors. The calculations across the processors works great, but again, it's like the function runs twice when I hit update dynamic mesh. Any ideas why this might happen? Could this be something to do with how node 0 communicates with the host? Maybe it's running my entire UDF twice?
File Type: png Screen Shot 2020-04-21 at 6.14.23 PM.png (55.3 KB, 0 views)
File Type: png Screen Shot 2020-04-21 at 6.16.13 PM.png (91.4 KB, 0 views)
buckngnr11 is offline   Reply With Quote
dpm, grid motion, udf
UDF problem: incorrect grid motion Fil FLUENT 5 December 19, 2020 10:16
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
decomposing a grid in parallel deeps SU2 2 January 29, 2014 02:01
HELP! grid check failed in parallel fluent restart FLUENT 0 March 5, 2011 10:55
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 15:17
