Flow recirculation - UDF boundary conditions
Like Tree8Likes
Old   May 21, 2020, 17:30
Default Thermal Condition
  #21
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The conditions you are using are correct. In that case, you should get maximum temperature at the top. How does the temperature profile look?
cfdEng_ likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 26, 2020, 18:49
cfdEng_ is on a distinguished road
If I impose Symmetry BC to the sidewalls (as discussed), I can't achieve a converged solution. I get a "hot core" in the middle of my duct and colder air elsewhere.
Nevertheless, by setting no-slip sidewalls, the simulation converges and I get a reasonable temperature profile.
The mesh I used works perfectly with a regular Velocity Inlet but it seems problematic for a Periodic Inlet. Do you think such an issue can be due to the quality of my mesh or is there something else I should look at?
Thank you very much in advance.
cfdEng_ is offline   Reply With Quote
Old   May 27, 2020, 05:12
Default Symmetry
  #23
vinerm's Avatar
Vinerm
Symmetry condition is equivalent to free-slip for momentum and adiabatic for thermal. So, if you want to model infinite domain across width, then it should be symmetry. If there are walls, then no-slip is more accurate. Even if you change it to no-slip wall, default for thermal boundary is still adiabatic and the changes in the thermal profile are only because of convection, which changed because of boundary condition being changed from free-slip (symmetry) to no-slip.
Whether to use no-slip or symmetry depends on whether you have infinite or finite domain across width.
cfdEng_ likes this.
Regards,
Vinerm
boundary, recirculation, udf
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Fluent udf F_PROFILE setting different boundary conditions for different faces syble Fluent UDF and Scheme Programming 0 March 31, 2016 00:35
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
