April 19, 2020, 15:51 |
Grid independence and grid adaptation?
Julianne Denise
Rep Power: 6 |
I'm not an expert with CFD. I'm just a little confused between doing a grid independence test and grid adaptation. I basically need to carry out grid adaptation for validating my ANSYS model. So I just want to confirm if grid independence test and grid adaptation are basically the same, just different terms? |
April 19, 2020, 21:54 |
Lucky
Rep Power: 66 |
Grid independence test is where you run a bunch of different meshes and calculate the uncertainty in the results due to the grid.
What's grid adaptation? If you're referring to an adaptive mesh, which is a dynamic mesh that changes on the fly, that's a completely different thing. |
April 20, 2020, 08:20 |
#3 | |
Julianne Denise
Rep Power: 6 |
I read that grid adaptation is another term for grid refinement. Which I THINK sounds similar to a grid independence test? where you change or refine the mesh values |
April 20, 2020, 09:38 |
#4 | |
Lucky
Rep Power: 66 |
Grid refinement is the process of changing the grid, whatever is the reason for doing so. I never heard grid adaptation until now, so I can't say. I wouldn't call it this. Just call it mesh sensitivity / grid independence like every one else if that's what it is. |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
Are you sure about grid independence? | Vignesh2508 | Main CFD Forum | 6 | August 23, 2019 06:14 |
Grid Independence of Boundary Layer | Luigi_ | STAR-CCM+ | 7 | January 15, 2012 14:40 |
Grid Independence of Boundary layer | Luigi_ | Main CFD Forum | 0 | December 14, 2011 13:42 |
grid independence questions | lucifer | FLUENT | 0 | December 14, 2009 19:59 |
