Material flow behaviour numerical simulation of dissimilar materials in fsw |
April 18, 2020, 12:43 |
Rohan
Rep Power: 6 |
I am doing numerical simulation on the material flow behaviour of disiimilar materials i.e steel and aluminum using ansys fluent. I have run the simulation without vof, and temperature dependent thermal properties of Cp and K and also used viscosity as an udf. My contour that I have attached I ran for 3000 iterations but the contour which came looks somewhat distorted or not as same as in literature. So can anyone suggest what can be the possible modifications? |
April 19, 2020, 00:44 |
#2 | |
kailash
Rep Power: 8 |
Hi, can y ou share the literature that you are working on.
April 19, 2020, 01:15 |
Rohan
Rep Power: 6 |
Search the below in google scholar--
"The study of material flow behaviour in dissimilar material FSW of AA6061 and Cu-B370 alloys plates". |
April 20, 2020, 05:59 |
Skewness in Results
The skewness in the results is most likely an outcome of thermal diffusivity difference. One side has higher diffusivity than the other.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
#ansysfluent #multiphase |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Coupling of drying process and flow simulation | franzdrs | Main CFD Forum | 0 | April 29, 2013 15:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
Solid-Liquid Two Phase Flow Numerical Simulation with the Finite Element Method | Qing Hao | Main CFD Forum | 2 | January 9, 1999 00:31 |
