HELP - Exhaust exit boundary condition. (ANSYS Fluent)
Old   April 18, 2020, 10:20
Default HELP - Exhaust exit boundary condition. (ANSYS Fluent)
Jesse Danquah
danquahj is on a distinguished road
Hello all,
For my university dissertation I am looking to use active flow control as a means of enhancing the performance of a diffuser equipped bluff body in ground effect. The effect I am trying to simulate is similar to the Blown Diffusers seen in Formula One cars of the 2011 era.
I have successfully completed CFD simulations of a baseline body.
My question concerns how to define the small face surface area on my body that will act as my exhaust exit, using boundary conditions? Is it a simple velocity inlet ?
How would i account for the temperature of the exhaust gases ?
Are there any other fluid properties i must account for to properly capture the behavior of exhaust flow.
Any advice would be greatly appreciated! Thank you.
https://drive.google.com/open?id=1y4...FM5uvpjzyQnJyA
https://drive.google.com/open?id=1rP...UMYQIWDU9cqX_A
Last edited by danquahj; April 18, 2020 at 10:24. Reason: Added Pictures of my geometry.
danquahj is offline   Reply With Quote
Old   April 20, 2020, 05:20
Default Exhaust
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Yes, you can apply velocity inlet, as long as the material density is constant. If it is not so, then you have to apply either pressure inlet or mass flow inlet along with temperature. Assuming that the material properties are constant and, consequently, you are not solving for Energy equation, then you can apply velocity inlet. However, ensure that the properties, i.e., density and dynamic viscosity are as per the exhaust temperature. Whether something else is important or not depends on the physical models being used, such as, species transport or energy.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 23, 2020, 12:05
Jesse Danquah
Thank you very much for your help, I have now successfully implemented your suggestions in my simulation.
Thanks again,
Jesse
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
