Zone name changes after every re-mesh
Old   April 17, 2020, 23:39
Smile Zone name changes after every re-mesh
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hi All,
I am using FLUENT watertight workflow to mesh the geometry, I am trying to do multiple design iterations by changing the step height.
Whenever I import the mesh from FLUENT Mesher to FLUENT solver I am getting different zone name and this is causing me trouble in using boundary condition files.
How can I maintain consistently the same zone name which I have specified in the SpaceClaim.
Thank you
Regards,
Sunil
sunilpatil is offline   Reply With Quote
Old   April 20, 2020, 04:34
Default Fluent Mesher
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Are you using Fluent Meshing, i.e., Fluent for generating the mesh or Ansys Meshing, which opens up if you click on Mesh within Workbench? I suppose it is latter and not the former. If names are created in SCDM, do check those are passed on correctly to Meshing. If that is not happening, then you have to look in SCDM for the reason.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 21, 2020, 02:08
sunilpatil's Avatar
sunil
I am using FLUENT Meshing, not the Workbench meshing. I have created names in SCDM.
Regards,
Sunil
Old   April 21, 2020, 04:32
Default Fluent Meshing
vinerm's Avatar
Vinerm
I am afraid I have hardly ever used Fluent meshing. However, if a CAD file loaded into Fluent Meshing maintains the names, which, of course, depends on the options chosen while importing CAD, then the names should not get lost while moving to Solver.
Regards,
Vinerm
Old   April 21, 2020, 05:30
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may change zone (and face) names inside fluent mesher.
But I've never tried to make script for that
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
fluent mesh, zone name
[ANSYS Meshing] Difficulty in mesh upload to ansys fluent Ayo_gboyega ANSYS Meshing & Geometry 1 June 17, 2018 04:02
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
