adiabatic and constant temperature boundary condition in transient Ground Heat Exch |
April 17, 2020, 19:33 |
teguh hady
Rep Power: 18 |
Dear all,
I am simulation Heat Transfer in slinky coil type Ground Heat Exhanger in transient. The Ground Heat Exchanger is buried 1.5 m from ground surface. initial The temperature distribution is collected from experiment field. Due to computer limitation, I just simulate one turn of slinky coil. I see many papers of Ground Heat exchanger use vertical side of ground as adiabatic boundary condition settings. But, my supervisor asks me to do Constant temperature Boundary condition according to temperature in ground distribution from experiment. I plan to simulate for 7 days of flow time. I am confused which boundary condition i should use. I would like to know the effect of both BCs in physical application in Ground Heat exchanger. Thank you Best regards Teguh
Now Or Never!!! |
April 17, 2020, 20:43 |
Lucky
Rep Power: 66 |
Your domain needs to be large enough such that both BC's give the same results. The only way to find out if that's the case... is to run both of them.
April 19, 2020, 19:30 |
teguh hady
Rep Power: 18 |
Dear LuckyTran
I see. Yes, I think the only way to check it is to run both BC's effect on the simulation result. Thank you for your help Best regards Teguh
Now Or Never!!! |
adiabatic wall, constant temprature wall, ground heat exchanger, transient |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
