Temperature dependent thermal conductivity and specific heat Property of mixture of t |
Rohan
Rep Power: 6 ![]() |
Can anyone tell is it possible to find out the temperature dependent thermal properties of the mixture of DH36 steel and aluminum? And, if possible then what will be the zener hollowman parameters that I should use for that mixture? Again, if I can use this technique to find out any temperature dependent properties for any mixtures between any two materials? |
#fluent #mixture |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
