How to write an expression in CFD-POST
Old   April 17, 2020, 00:41
Default How to write an expression in CFD-POST
hitzhwan is on a distinguished road
How to write an expression in CFD-POST?
the down is the errors.
hitzhwan is offline   Reply With Quote
Old   April 17, 2020, 03:56
Default Expression
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Your expression is correct. The problem most likely is with the name; CFDPost is case-sensitive. Wall and wall are different.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 17, 2020, 13:13
Default Thanks, but I do not understand your meaning. You mean I should use "Wall" but not "
Thanks, but I do not understand your meaning. You mean I should use "Wall" but not " wall", but this is now written by me, but just use the right click to get it. Additionally , what is PM?
Old   April 17, 2020, 13:18
Default Wall
vinerm's Avatar
Vinerm
The error is Temperature. CFDPost uses only T and not Temperature.
PM implies private message within cfd-online.
Regards,
Vinerm
Old   April 17, 2020, 13:29
Default No, it is not the problem, the Temperature is just the list of variable in the CFDPOS
No, it is not the problem, the Temperature is just the list of variable in the CFDPOST, both T and Temperature is Ok. Because I tried it successfully. The most problem I think it the 300[K], why the K is italic?
Old   April 17, 2020, 13:36
Default Unit
vinerm's Avatar
Vinerm
Units are always italic.
Click on More... when it shows the error. See it shows something useful though I doubt that.
Regards,
Vinerm
Old   April 17, 2020, 13:37
Default Space
vinerm's Avatar
Vinerm
It appears you do not have a space between 300 and [K]. Space is must.
Regards,
Vinerm
Old   April 17, 2020, 13:43
Default But what is the reason? Can you try it by yourself?
Old   April 17, 2020, 14:01
Default Expression
vinerm's Avatar
Vinerm
It works perfectly at my end, with T as well as with Temperature. With or without space. So, the only remaining portion is boundary name. Check it against the names it shows in the Tree in Outline Tab.
Regards,
Vinerm
Old   April 19, 2020, 20:37
Default Yes , you are right. It cannot be defined as wall name, when it changes ,it works. Th
Yes , you are right. It cannot be defined as wall name, when it changes ,it works. Thanks .I have a another question, why I can not find the static pressure in the CFD post, I only can use the pressure variable. Why?
Old   April 19, 2020, 20:46
Default What's more, the static temperature also can not find.
  #11
Old   April 20, 2020, 06:12
Default Variable Names
  #12
vinerm's Avatar
Vinerm
The names of the variables are defined to ensure that there is no ambiguity. For static values, just the regular names are enough. So, static temperature is just Temperature and static pressure is just Pressure. For total or absolute, Total or Absolute are used as first word.
Regards,
Vinerm
Old   April 20, 2020, 12:57
Default I find that the total temperature is equal to static temperature for the imcompressib
  #13
I find that the total temperature is equal to static temperature for the imcompressible flow. But the total pressure is not equal to the static pressure. The total pressure should add the dynamic pressure.
Old   April 20, 2020, 14:12
Default Total values
  #14
vinerm's Avatar
Vinerm
Both, total temperature and total pressure, are functions of velocity and have got nothing to do with compressibility. Both are equal to their static counterparts only when the velocity is 0. Otherwise, total values are always sum of static and dynamic values.
Regards,
Vinerm
Old   April 21, 2020, 10:41
Default But I cannot find the total pressure or total temperature in the CFD POST
  #15
Old   April 21, 2020, 10:44
Default Variables
  #16
vinerm's Avatar
Vinerm
Total Pressure and Total Temperature are always there. Variables are listed alphabetically in CFDPost.
Regards,
Vinerm
Old   April 21, 2020, 22:47
Default As you can see, we can not see the total pressure or total temperature in the list, I
  #17
As you can see, we can not see the total pressure or total temperature in the list, I also search in the other option, it also does not have. Moreover, we cannot find the phase fraction ,too. Do you know why?
Old   April 22, 2020, 05:26
Default Total Values
  #18
vinerm's Avatar
Vinerm
Since total values are velocity dependent, those are specific to each phase, i.e., total pressure for Phase 1 is different from that for Phase 2. All these would be available under Phases. Same is true for phase (volume) fraction.
Regards,
Vinerm
Old   April 22, 2020, 12:05
Default You see, in the phase interface, we can not see those variables. Why?
  #19
Old   April 22, 2020, 12:11
  #20
vinerm's Avatar
Vinerm
It appears that you are using either VOF or Mixture model. That implies there is single set of Navier-Stokes equation. In this case, there would be single velocity field, hence, single total pressure and total temperature. So, ignore my previous post. About the unavailability of total values, it is strange. However, it is possible that you wrote selected variables. If you loaded Fluent data file, then total values should be there. However, you can just create total values yourself using expressions.
Regards,
Vinerm
CFD Post Expression creation jasonbot CFX 2 July 15, 2015 07:21
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
CEL mathematical functions in CFD Post Jonathan CFX 9 November 5, 2012 09:37
Poly lines in CFD Post ashtonJ CFX 0 December 2, 2010 03:46
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
