How to resolve negative torque values for a VAWT in Ansys Fluent? |
April 13, 2020, 07:55 |
khadija rahal
Rep Power: 12 |
I am working on the vertical axis water turbine project. after the computations, the average Monitors value I got was a negative value. This would suggest a negative torque value which is clearly wrong, I do not know the exact reason for this . I am getting negative moment values when I put moment center as (0 0 0) and moment axis as (0 0 1). but I get the positive moment when I put (0 0 -1) direction. I would really appreciate any help you can offer. Thanks |
April 13, 2020, 08:59 |
Torque
The sign of torque is pointing towards its rotation direction. If you are expecting it to be positive about (0 0 1), then it should be rotating in CCW direction.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Wind Turbine (VAWT) - Negative Moment in Fluent | dalecooper | FLUENT | 27 | December 14, 2023 06:03 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
