April 11, 2020, 06:57 |
CFD-POST dont show only white backgound
je young kim
Rep Power: 13 |
Hello all.
I just installed ANSYS 15 and CFD-POST dont show any results after Fluent simulation. I can see some data loaded in left pannel but in the view pannel nothing appear. I tried open CFD-POST only but same. I re-installed ANSYS a couple of time but no avail. Any suggestin or recommendation? Fleunt is working well. Only CFD-POST has some issue... CFD-POST Error.jpg |
April 11, 2020, 10:09 |
Data
There is no data loaded, at least not in the image shown. However, the problem could be with the video library. Try starting CFDPost with option -gr mesa. For this, you have to start CFDPost from command prompt. This option might also be available under Options within CFDPost
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 12, 2020, 02:34 |
Data can be loaded
je young kim
Rep Power: 13 |
Actually, Data can be loaded. In the uploaded figure, I just snapped it without loading the data. The new snap-shot is attached with loaded data. Do you think the problem comes from the graphic card? It was fine last time when I used it few months ago. I have no idea how to figure it out.
April 12, 2020, 16:56 |
Graphics
It could be graphics or driver. Try using different graphics option. I suppose this could be because CFDPost is trying to use hardware for graphics but it is not working. You have to start with -gr <options> where options could be mesa, opengl, or some other graphics. Check for the availability on your system by trying mesa.
April 15, 2020, 13:17 |
It didn’t t work with prompt.
je young kim
Rep Power: 13 |
I have tried out as suggested with commend prompt.
It didnt work. I can open CFD post with only ogl option instead of mesa and opengl. But there is still white screen and not showing anything. Any other auggestion? I already did re-install a couple of times. It seems like bug. I will appreciate if any of you comment on this matter. I am suffering for few weeks due to this matter... |
April 15, 2020, 15:56 |
.cfx
Try deleting .cfx directory in user's account or home directory. You need to ensure that no CFX process is running before deleting it. It will remove all user specified settings, nothing else. It won't affect the installation or your files.
April 17, 2020, 04:52 |
je young kim
Rep Power: 13 |
Thanks vinerm.
I figured it out my problem. As you expected, my graphic card was troublesome. After updating the graphic card driver, all is working normally. But I am blurred that why it worked well before. Anyway, all solved. |
cfd-post, error, white back ground |
HOW TO SHOW TIME IN ANIMATION IN Fluent CFD POST | niazgdc | FLUENT | 0 | October 12, 2017 03:58 |
On the CFD market and trends | sbaffini | Main CFD Forum | 14 | June 13, 2017 12:48 |
how to show trapped particle in cfd post | n9879005 | ANSYS | 0 | May 18, 2017 02:08 |
Post-processing star ccm+ results in Ansys CFD Post | sidharath | STAR-CCM+ | 4 | April 10, 2017 12:49 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 07:21 |
