Error In the Result Section of Fluent
Old   April 11, 2020, 01:18
Default Error In the Result Section of Fluent
Sanjay
skdubey is on a distinguished road
Hi Friends,
I just started using the Ansys. Whenever I try to open the Result file.
It doesn't get open. I am not sure if it is license issue or something else.
I hope if you can suggest to me something.
thanks
skdubey is offline   Reply With Quote
Old   April 11, 2020, 10:25
Default Installation
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
This appears to be an installation issue. Since the machine is Windows based, it puts a certain restrictions on installation. If the installation was NOT done via Run As Administrator, then most of the features and functions won't work. If it was installed properly, then you should try to open CFDPost separately, i.e., outside WB.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 14, 2020, 11:10
Sanjay
This is a temporary directory which gets put in your local users temporary file path. For windows 7 that is C:\Users\<UserName>\.cfx by default.
It work
Link:PostGui_ogl.exe has stopped working
Old   April 14, 2020, 11:27
Default Issue
vinerm's Avatar
Vinerm
I am afraid I could not understand your question. Or is there none?
Regards,
Vinerm
#ansysfluent, #licenseissue
solution result of any parameter at all grid points in ANSYS Fluent in data file? Muhammad Shad FLUENT 2 September 25, 2018 14:02
Problem with the ANSYS fluent result raghuramswaroop FLUENT 0 June 11, 2018 16:13
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
error using Fieldview to read fluent result ggbaby FLUENT 1 June 29, 2005 07:56
