Temperature dependent thermal conductivity and specific heat Property of DH36 steel
Old   April 10, 2020, 14:07
Default Temperature dependent thermal conductivity and specific heat Property of DH36 steel
Rohan
rohan@123 is on a distinguished road
Hi everyone.
I am modelling material flow behaviour in ansys fluent in which I am using temperature dependent thermal conductivity and specific heat of DH36 steel as polynomial function.
If anyone can provide some references for the above mentioned property then it will solve my purpose.
rohan@123 is offline   Reply With Quote
Old   April 10, 2020, 16:33
Default Reference
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
If you are already using these properties, you might have taken those from some reference! Here is one article that shows the required properties
https://www.researchgate.net/publica...eel_assemblies
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
