Strouhal Number of a square cylinder not matching |
April 10, 2020, 01:46 |
Saugat Shrestha
Rep Power: 7 |
I trying to do a 2D model of the square cylinder for a Reynolds number of 50000. I am using the K-omega SST model. I have satisfactory results with the drag and lift. However, I am having some discrepancies in Strohaul's Number. I am getting a number of 0.08, whereas the expected number is in the range of 0.12.
Hope you can help. Thanks in advance. |
April 10, 2020, 04:38 |
Frequency
Drag and lift are not much affected by the resolution but frequency is. A higher frequency requires finer resolution. You need to check if you are using fine enough temporal as well as spatial resolution to resolve the frequency for St of 0.12.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
2d model, square model, strouhal number |
[ImmersedBoundary] Immersed Boundary Method in OpenFOAM-3.1-ext | miladrakhsha | OpenFOAM Community Contributions | 106 | July 3, 2023 11:26 |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 13:01 |
Flow past a cylinder, Reynolds No: 100, Tracking strouhal Number. | Karan | FLUENT | 11 | November 14, 2016 05:49 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
