UDF parabolic velocity profile issue
Old   April 7, 2020, 02:20
Default UDF parabolic velocity profile issue
Koo How Boon
Kenzhia3310 is on a distinguished road
I have an issue about parabolic velocity profile in my .c file.
I want to create a parabolic inlet with 0.3m/s max speed and pipe diameter is 8mm.
And I found this code from the others, is this applicable for my case?
THE CODE SHOWN AS BELOW:
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND]; /* this will hold the position vector */
real y, h;
face_t f;
h = 0.004; /* inlet height in m */
begin_f_loop(f,thread)
F_CENTROID(x, f, thread);
y = 2.*(x[1]-0.5*h)/h; /* non-dimensional y coordinate */
F_PROFILE(f, thread, position) = 0.3*(1.0-y*y);
end_f_loop(f, thread)
Kenzhia3310 is offline   Reply With Quote
Old   April 7, 2020, 08:31
Default Code
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Yes, this would work.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 7, 2020, 11:29
Koo How Boon
I have applied the parabolic velocity into my biogas-air premixed combustion.
However, I didn't get my expected result.
Here is my settings for the system(Stoichiometric mixtures)
1.Air fuel inlet velocity: 0.3 m/s parabolic velocity
Coflow inlet velocity: 0.05m/s
2. 40% CO2 and 60% CH4 for fuel; 21% O2 and 79% N2 for air
3. Mole fraction (air fuel inlet): CH4= 0.0894, O2 = 0.1788, N2 = 0.6722, CO2 = 0.0596
Is there any problem for my settings here to get the flame?
Old   April 7, 2020, 12:20
Default Reactions
vinerm's Avatar
Vinerm
Parabolic velocity profile has got nothing to do with flame. Even if you use flat profile, it may or may not result in flame. Combustion depends on correct setup of combustion model, initialization, material properties, and thermal boundary conditions.
Regards,
Vinerm
UDF Parabolic 2D Velocity Profile Issue chrislyn FLUENT 2 December 11, 2018 13:11
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 07:45
UDF for 3d inlet parabolic velocity profile ? shahzeb irfan Fluent UDF and Scheme Programming 10 March 28, 2016 16:00
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface emmkell Fluent UDF and Scheme Programming 2 October 21, 2011 14:12
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 20:09
