April 6, 2020, 23:11 |
Pseudo Transient method
Diego Jerez
Rep Power: 6 |
Hi to all,
I have a doubt about the pseudo transient method. On the Theory guide you can find how this method calculate this time size for each iteration. Now my question is, this time size have relation with courant number? How? Because when you use a coupled implicit method you cant choose a courant number. Wich is the criteria to converge? If there are some documents or papers, i'd be grateful Greetings! |
April 8, 2020, 11:23 |
Pseudo Transient Method
Fluent, and other CFD tools, use implicit relaxation of equations to stabilize the numerical process. However, there are at least two ways to do that. One is by specifying a Courant number. This is different from CFL but definition is similar, hence, called Courant number. The other option is to use a false time marching. This is pseudo-transient. So, instead of CFL, defined in Coupled Solver, is used. So, in a way they are related but used exclusively.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 8, 2020, 12:43 |
Diego Jerez
Rep Power: 6 |
I found this information too. There you have the relation between CFL and the relaxation factor. Link: https://www.afs.enea.it/project/nept...underrelax-eqn |
April 8, 2020, 13:15 |
Courant number and Time-step
Yes, there is relation between implicit relaxation factors and CFL because implicit factors are not defined by the user. User can only either specify CFL or explicit relaxation factors. However, your question was about CFL and time-step. Therefore, I mentioned that as such there is no direct relation but they convey similar information. Pseudo-transient has a physical basis but not CFL.
April 8, 2020, 14:02 |
#5 | |
Diego Jerez
Rep Power: 6 |
- the pseudo transient method used the under relaxation factor to stabilize the numerical process where this factor is the time step size, right? - there's not relation beetwen the courant number and the time step used in the under relaxation method. So, this time step size is used to converge without the criteria of courant number? wich is the criteria in that case, just obtain the residuals? Thanks for your answers! |
April 8, 2020, 15:20 |
Convergence
The criteria for convergence are not defined by either time-step or Courant or URFs, implicit or explicit. These are only methods to ensure numerical stability. To check for convergence, residuals and monitors are required. Residuals should always be less than 1 but don't have to be always very small. Smaller residual does not always mean accurate results. For that, field quantities should be monitored.
April 8, 2020, 15:50 |
#7 | |
Diego Jerez
Rep Power: 6 |
Greetings and have a good day! |
Pseudo Transient vs Time-Averaged solutions in Fluent | yousefaz | FLUENT | 6 | March 16, 2023 00:41 |
Counting particles in transient simulation using Fluent DPM method | mali28 | Fluent UDF and Scheme Programming | 0 | April 25, 2017 07:36 |
Pseudo Transient | cfd seeker | Main CFD Forum | 0 | October 8, 2012 01:47 |
Pseudo Transient | cfd seeker | FLUENT | 0 | October 8, 2012 01:46 |
Steady method without pseudo time | Vasiliy | Main CFD Forum | 0 | February 21, 2011 13:51 |
