April 5, 2020, 16:47 |
Sublimation in Fluent
Rep Power: 10 |
I would like to simulate sublimation model in Fluent.
I want to define the mass of solid as an initial value. Where can I define it? I can't find the way to define it. Thank you in advance. |
April 6, 2020, 08:51 |
Sublimation
There is no in-built mass transfer model for sublimation. So, you have to define it yourself. Mass is never provided as initial value for any field. It is always the size, provided as mesh, and the material density. Then those are used by Fluent to define the mass.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
cfd, fluent, sublimation, udf |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 09:08 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
batch mode fluent - beginner | CompIng | FLUENT | 1 | November 30, 2015 12:48 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
