April 4, 2020, 05:18 |
Turbulent Heat Flux Extraction
Oguzhan
Rep Power: 9 |
Hi all,
Hope everyone is well. Can anyone please guide me on extracting turbulent heat flux <u'T'> from k-w SST and LES? Thanks. |
April 6, 2020, 06:09 |
Turbulent Heat Flux
Do you want this at a boundary or at interior faces of the mesh?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 6, 2020, 17:02 |
Oguzhan
Rep Power: 9 |
April 7, 2020, 15:42 |
Turbulent Heat Flux
For LES, this definition makes sense but has neither of these fields available. So, you have to define it either using k or subtract heat flux due to molecular diffusion from total to fetch turbulent heat flux.
April 11, 2020, 11:37 |
#5 | |
Oguzhan
Rep Power: 9 |
Many thanks |
April 11, 2020, 12:12 |
Turbulent Heat Flux
For RANS, you can determine u' using k,
Whether LES or RANS, turbulent heat flux is product of u' with mean T and not T'. Another method of determining turbulent heat flux in RANS is via and mean temperature gradient. You can use this for LES as well, however, for LES, you directly have u'. I am not sure but Fluent may directly have turbulent heat flux field available.
April 12, 2020, 11:37 |
Oguzhan
Rep Power: 9 |
Many thanks. |
April 12, 2020, 15:28 |
Turbulent Heat Flux
You are correct, in similarity with Reynolds stress, turbulent heat flux uses temperature fluctuation and not it's mean. It's only if turbulent diffusivity is used that the gradient of mean makes sense for turbulent heat flux determination.
fluctuating temperature, fluctuating velocity, k-wsst, les, turbulent heat flux |
Some questions about flow boiling simulation in Fluent | beastieboys6 | FLUENT | 8 | November 20, 2017 23:47 |
Sign of Heat Flux at wall | Kyung | FLUENT | 2 | February 26, 2016 16:25 |
chtMultiRegionFoam heat flux | sailor79 | OpenFOAM Running, Solving & CFD | 0 | September 27, 2013 08:08 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
