Setting cell zone conditions
Old   April 2, 2020, 10:52
Default Setting cell zone conditions
Mauro
Mnasso is on a distinguished road
Hi everyone I've a question about cell zone conditions in Fluent 19.
When I read a mesh (I'm using ansys meshing) all the bodies are set as fluid and I have to change them one by one to solid. Also I can copy one body conditions to others if they are different (I mean I can transformed a fluid to solid by copying their properties).
Is there any possibility to pre-set the cell zone conditions from the ansys meshing or other way to do it as I have a lot of different bodies and materials and doing this one by one it is very time consuming.
Thank you very much.
Mnasso is offline   Reply With Quote
Old   April 6, 2020, 06:26
Default Cell Zones
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
At the CAD and meshing stage, there is option to set whether a domain is solid or fluid. However, a better option would be to use command
def bc zone-type
to set all those zones to solid that you want. Furthermore, in newer versions, Fluent allows selecting multiple cells zones and then changing those to solid in one go.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   August 29, 2021, 08:35
Sai Krishna
Sai Krishna is on a distinguished road
def bc zone-type
Hi Vinem,
Can you confirm whether the feature you mentioned is available in Ansys 2020R2, as Iam unable to select more than 1 entity at a time in GUI cell zone conditions. I need to give it for >60 parts. So its highly tedious to do. and I agree I could have given that in WB or spaceclaim. But is there anyway like script file which helps in this?
Regards.
Sai Krishna is offline   Reply With Quote
cell zone conditions, mesh
Setting cell variable values in a fluid zone using UDF eromon84 Fluent UDF and Scheme Programming 6 March 28, 2021 12:59
domain ID and cell zone ID Weiqiang Liu FLUENT 0 September 15, 2019 13:54
what is the function of cell zone conditions in fluent ? jiechelsea FLUENT 4 May 17, 2018 01:37
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
