Removing backflow
Old   April 1, 2020, 05:44
Default Removing backflow
Franke is on a distinguished road
I am modelling a body in a 3d mutliphase domain, of water at the bottom and air on top, I am interested in the drag forces on the body which is partially submerged. my velocity inlet is 2 times the length away from the body and the outlet is 4 times length away, I am getting a lot of back flow and the mass flux is very highly positive. I am using symmetry through my body and all other boundaries are over 1L away from the body
Any suggestions on ways to reduce the backflow? Ideally zero backflow but that is not always possible, I have attempted to use both outflow and pressure-outlet. I am using the student software more or less to capacity on the number of nodes so very restrained on adding any additional length to the domain.
Thanks in advance!
Franke is offline   Reply With Quote
ansys, backflow, fluent, multiphase, vof
backflow chirag.palan1987@yahoo.in FLUENT 0 June 1, 2015 03:42
Inducing backflow restrictions in domain interface for multiphase flow DarrenC CFX 4 August 6, 2014 22:17
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 12:31
Problem with integrals and averages if backflow?? Amit FLUENT 0 October 19, 2006 19:54
Swirl in backflow on pressure outlets Jonas Larsson FLUENT 17 February 3, 2000 03:14
