March 31, 2020, 18:24 |
fluent les sgs effective viscosity
joe
Hallo,
I can't find the definition or equation of sgs effective viscosity in LES. Could anyone help? Thank you Best Regards Eugene |
March 31, 2020, 22:20 |
Lucky
Rep Power: 66 |
The SGS turbulent viscosity or SGS eddy viscosity is described in SGS models. In Fluent, you are most likely using the Smagorinsky-Lilly or dynamic Smagorinsky approach.
Effective viscosity is the sum of molecular viscosity and turbulent/eddy viscosity. We don't normally talk about a SGS effective viscosity. Are you sure that's what you're looking for? |
March 31, 2020, 23:03 |
joe
Hi LuckyTran,
Thank you for your reply. I used Smagorinsky-Lilly for the simulation, there are only subgrid turbulent viscosity and subgrid effective viscosity under the turbulence (fluent19). I'm confused about these names. mu_eff=mu+mu_t (mu_eff is effective/total viscosity, mu is molecular viscosity and mu_t is turbulent viscosity). But in this case means mu_eff the subgrid effective viscosity? |
April 2, 2020, 01:34 |
Lucky
Rep Power: 66 |
Where did you even hear the term effective SGS viscosity? It's not a part of any normal LES nomenclature.
The subgrid stress is purely turbulent so there is no notion of molecular SGS and effective viscosity as far as the SGS is concerned. Ppl that examine effective viscosity in LES are back-calculating the effective viscosity as per the Boussinesq hypothesis (which is no longer specific to the SGS) or they are studying numerical schemes, i.e. a numerical viscosity that they call an effective viscosity. In the latter case, effective viscosity could mean anything. |
fluent |
Fluent PDF Combustion viscosity problem | laxwendrofzx9r | FLUENT | 0 | December 6, 2011 10:21 |
How to access the subgrid-scale (SGS) stresses with LES (FLUENT) ? | Marvin | FLUENT | 0 | May 12, 2011 13:13 |
Link between eddy viscosity and subgrid-scale turbulent viscosity in LES | Marvin | Main CFD Forum | 6 | December 4, 2009 12:08 |
Which SGS viscosity model is most popular in LES? | leaf | Main CFD Forum | 1 | August 1, 2006 06:04 |
effective viscosity in RNG k-e turbulence model | Ellen | Main CFD Forum | 1 | August 20, 2002 03:20 |
