TUI coefficient of drag and lift
Old   March 29, 2020, 23:58
Default TUI coefficient of drag and lift
ZT
Tait10 is on a distinguished road
Morning all,
I am currently using HPC to simulate flow around a wingsuit. I have not yet found a way to find the Cl and Cd of the wingsuit, I can so far only find the lift and drag in Newtons. I am limited to using the TUI so does anybody know what the commands are to either convert the lift and drag into coefficients like you can on a Gui or just have it as coefficients in the first place?
TIA,
Zach
Tait10 is offline   Reply With Quote
Old   March 30, 2020, 05:33
Default Coefficients
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The coefficients are nothing by normalized force values. You just need to divide force in N by dynamic pressure of freestream to get coefficient values. As far as commands are concerned, you will find those under solve rep-def. But those will setup monitors. To fetch values, best would be to calculate at your end.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 30, 2020, 08:29
ZT
Hi there,
Thanks for your answer. I can get cd and cl when I set them up on the GUI, should there not be some TUI system for doing this as well? It seems counterintuitive.
Old   March 30, 2020, 09:40
Default GUI and TUI
vinerm's Avatar
Vinerm
Not every command in TUI has a parallel option in GUI, similarly, not every GUI option has a TUI command. You can setup a monitor for coefficient, you can print their values as the simulation proceeds, but there is no option to compute by giving a command. Possibly in future release.
Regards,
Vinerm
coefficients, tui
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 07:04
Fluent 19.0 Lift and Drag Coefficient Monitors TeriSerugi FLUENT 0 February 6, 2019 18:21
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
drag and lift coefficient Noé Siemens 5 July 13, 2004 11:21
