March 26, 2020, 04:55 |
Mesh Embedding
Anirudh Reddy Bendaram
Hello Everyone,
I am trying to build a thermal model for a single cell battery. I am trying to refine the meshing around my battery, which is inside an enclosure by mesh embedding (by creating an other enclosure around the battery and meshing it). I have meshed the battery (dia = 18mm, length = 65mm cylinder) at 1mm, the total enclosure (200mmx200mmx200mm cube) at 10mm. I want to refine the meshing by creating an other enclosure(25mmx25mmx80mm) around the battery at 2mm. How can I do that using Fluent? Last edited by Anirudh Reddy Bendaram; March 26, 2020 at 11:19. |
March 26, 2020, 07:29 |
Embedding
I am afraid your requirement is not very clear. The terminology is also not standard; what do you mean by embedded mesh?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
battery model, mesh embedding, mesh refinement |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] High quality mesh for wind in complex urban environment | ziboaa | OpenFOAM Meshing & Mesh Conversion | 1 | January 12, 2021 15:33 |
[ICEM] Bad Quality Hybrid Mesh External Flow | tim13 | ANSYS Meshing & Geometry | 0 | March 8, 2020 02:22 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
