March 25, 2020, 12:17 |
Print to console simulated plots
Mikel
Rep Power: 6 |
My dude is when I simulate a model in ANSYS Fluent and I close it. After that, I open it again but I donīt know how I can print to console again the plots that I have simulated before. Somebody can help me? Thanks beforehand. |
March 25, 2020, 13:16 |
Plots
Which plots do you want to be plotted?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
March 25, 2020, 13:27 |
Report Plots
These plots are not saved in data files. So, these can be replotted only if you saved these plots as files. Otherwise, only the latest data is available. For a steady-state simulation, it does not matter since only the last value is important, provided the value has stabilized.
March 25, 2020, 14:54 |
Report File
If you have report file saved, then it is saved. You can plot it again. Open the Report plot where it is set and click on Plot. If there is no such icon, then just run 1 iteration and the plot will be plotted automatically.
how to get Sutherland and JANAF coefficients of air? | immortality | OpenFOAM Running, Solving & CFD | 64 | October 18, 2022 10:17 |
How to print k (TKE) on the console at every iteration..?? | last_jedi | OpenFOAM Programming & Development | 1 | May 23, 2018 16:24 |
Hybrid discretisation - blend factor | gcoopermax | CFX | 5 | September 23, 2016 08:05 |
[blockMesh] Another cylinder question | bendel_boy | OpenFOAM Meshing & Mesh Conversion | 5 | January 6, 2015 05:09 |
drawing of contour plots | chinthakindi | Main CFD Forum | 1 | April 27, 2004 04:33 |
