Help regarding dynamic velocity input in boundary condition
Old   March 23, 2020, 04:30
Default Help regarding dynamic velocity input in boundary condition
chodvadiyaharsh is on a distinguished road
Sub:help regarding how to apply dynamic velocity expression in inlet boundary condition setup
respected all members
i have an problem regarding how to apply expression of velocity in inlet boundary condition ansys 19.2 version. I can't find that function in ansys version 19.2.i have an project on wind .dynamic wind means velocity wind is apply by power law equation which i have not found.
Beside this option i have see in student version r19 which i have saw in pic .
So please help me in this because my whole project is dependent on this which is stopped since 1 month. I try a lot to solve this on yo-tube and google but not found properly
MAIL:chodvadiyaharsh24@gmail.com
chodvadiyaharsh is offline   Reply With Quote
Old   March 23, 2020, 04:35
Default Powerlaw
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
There is nothing called a powerlaw function defined within Fluent. This is, most likely, an expression defined by the user. If it would have'd been an inbuilt function, it would require some data from user. So, you need to check for expressions defined in the case from where you took this picture and then define that expression in your case.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 22:18
