Urgent:error regarding save
Old   March 23, 2020, 03:12
Default Urgent:error regarding save
chodvadiyaharsh is on a distinguished road
RESPECTED MEMBERS OF FORUM
SUB:error regarding save the model of ANSYS FLUENT
i have use the ANSYS 2019 R2 STUDENT VERSION.
i have model as per steps like 1)geometry then 2)messing then 3)setup
all task completely with zero error
but when i cancel all task and save from ANSYS WORKBENCH
FROM task bar-file>save>d drive(file name)
then model will save with appropriate name
but after that when i open this model there is shown error regarding save and model will be corrupted. solution will not open.
i have try so much but there is same error in all models .
please help me .....my project has sttoped because of this kind of error since 1 month
> Cannot change directory to D:\DISSERTATION MODEL\RECESSION\0.5B\21-03-2020\RE-0.5-30?_files\dp0\FFF\FluentWarning: Ignoring WB preference save-post-processing-images
Error: File "D:\DISSERTATION MODEL\RECESSION\0.5B\21-03-2020\RE-0.5-30?_files\dp0\FFF\Fluent\FFF-1.cas.gz" not found!
Error Object: #f
Error: cl-set-default-save-dir: path does not exist.
Error Object: "D:\DISSERTATION MODEL\RECESSION\0.5B\21-03-2020\RE-0.5-30?_files\dp0\FFF\Fluent"
email id:chodvadiyaharsh24@gmail.com
chodvadiyaharsh is offline   Reply With Quote
Very quick - Journal file command to save monitors lcaBR FLUENT 2 October 18, 2022 13:26
[General] Save Data for all time steps mvdl1996 ParaView 3 March 30, 2021 03:12
save to variable filename inside loop FrankR Fluent UDF and Scheme Programming 5 January 30, 2019 12:16
save case & data Saman95 FLUENT 1 August 12, 2018 07:09
[General] Save Animation Settings TomBot ParaView 2 August 26, 2017 08:54
