March 15, 2020, 12:42 |
Multiphase - Define pressure for 1 phase
Rep Power: 6 |
I would like to set the pressure of one of my phases in multiphase simulation for the whole fluid region during the whole transient simulation. Can someone tell me how I can define this in ANSYS Fluent, please?
I got 2 phases. The pressure of one of these (air) causes divergence problems but is not of interest. I want to assume that this pressure is constantly ambient pressure to stabilize the calculation. I can't find an option for this. Does anyone have an idea? |
March 15, 2020, 13:15 |
Pressure in Multiphase Flow
In a multiphase simulation, pressure is shared across the phases, i.e., pressure is defined for the mixture and not for the phases. So, you cannot set pressure for one phase. If you're observing divergence due to pressure, then there is some issue with the setup or initialization. As far as air is concerned, gauge pressure within this phase would anyway be more or less close to 0 Pa.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
How to access only one phase in multiphase model by UDF | wersoe | Fluent UDF and Scheme Programming | 1 | January 4, 2017 08:11 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 17:12 |
Pressure correction at pressure outlet (multiphase) | shikamaru | FLUENT | 1 | April 6, 2014 03:31 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
Multiphase flow problem | icedou | FLUENT | 6 | July 10, 2005 03:52 |
