Ansys fluent Boundary condition help
Old   March 10, 2020, 15:35
Default Ansys fluent Boundary condition help
dasareddygari rajasekhar reddy
rajasekhar reddy is on a distinguished road
Hello all,
we are simulating a multi species setup in our case. we have a room where the Supply volume flow rate is 10360 L/S. our extract volume flow rate is 9320 L/S. so we have a difference of 1040 l/s, which is accumulating in the fluid domain. for now we are using velocity inlet boundary condition at inlets and velocity inlet boundary condition with negative velocity at outlets.
in the current case we have to maintain a positive pressure in the fluid domain. so, we are supplying more inflow compared to outflow.
our simulation is running with not very great convergence of continuity but we are able to achieve some simulation contours.
will anyone please suggest what are the other boundary conditions if the above conditions are not correct.
Also will any one please suggest is there any possible way to maintain positive pressure with mass imbalance in our current simulation.
rajasekhar reddy is offline   Reply With Quote
Old   March 10, 2020, 16:13
Default Velocity BC
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
A combination of velocity at both, inlet and outlet, is not an appropriate set of boundary conditions. And for your case, velocity condition is wrong at either of the boundaries. The options you have are mass flow inlet or pressure inlet and similarly mass flow outlet or pressure outlet.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 11, 2020, 02:23
Default Velocity boundary conditions
Thankyou Vinerm for your quick response.
i have one more doubt. if for suppose i will match my inlet flowrate with outlet flowrate in the above case. is it possible to use velocity boundary condition at both openings.
Thankyou,
Reddy.
Old   March 11, 2020, 03:55
Default Velocity at both boundaries
vinerm's Avatar
Vinerm
Theoretically, you can use that combination but you will get into numerical errors with most of the CFD codes. So, it is recommended not to do that.
Regards,
Vinerm
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
