DPM collision rate normalized?
Old   March 5, 2020, 09:33
Default DPM collision rate normalized?
Sadjad
sajad2006 is on a distinguished road
I have a 2D model with DPM, and I want to normalized the collosion per partice (i.e. number of collosion events divided by number of particles).
Is there a way to define a function/parameter and print it with each time step?
I tried to normalize collosion rate by particle concentrations, applying densities etc. The number of particles in domain, however does not match to the number which I get from Report/Discrete/Summary. Any idea why?
thanks in advance
sajad2006 is offline   Reply With Quote
Old   March 5, 2020, 09:54
Default Collision
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Which collision model are you using? Is it O'Rourke or DEM?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 5, 2020, 10:00
Sadjad
I use O#Rourke.
Does it make a difference, I am curious?
Old   March 5, 2020, 11:45
Default Normalization
vinerm's Avatar
Vinerm
There are significant differences since one is statistical while other one is not. However, it is not of much relevance here. If the number of particles is fixed in your case, then it is much easier because you can create a custom field function. However, if that is not the case, then you can define it as ratio of volume integral of collision rate and volume integral of number density.
Do note that the summary displays both, number of parcels and number of particles and most of the times these will be different. Tracking is done for parcels and not for particles.
Regards,
Vinerm
collision frequency, dpm fluent
Epyc 7551 vs 6850K; Ansys Mechanical Bench Duke711 Hardware 24 March 26, 2020 11:16
Number of particles based on mass flow rate in DPM Saptarshi Fluent Multiphase 1 May 24, 2018 09:49
dpm mass flow rate yow FLUENT 0 February 14, 2017 14:15
Calculating flow rate -DPM dhaya400 Fluent Multiphase 1 July 6, 2016 13:06
DPM flow rate sfotovati FLUENT 0 November 5, 2013 20:42
