Arslan Hasan
Rep Power: 6 ![]() |
I'm doing a fluent analysis on acoustic sensor. My objective is to generate a sound source on the sensor and and it should responds how much pressure is forced on the sensor. I have tried it in fluent. But the problem is when the sensor move away from sound source, the pressure increases on the sensor. but it shouldn't be increase. I'm following the attached paper.
Looking for your guide. Thanks https://www.nature.com/articles/srep29957 |
What kind of source are you providing? Is it a localized one?
And what models are you using in your case?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Arslan, I recommend using the forum for discussions instead of PM.
You may share more details about your case, your approach, and issues so that users on the forum could help as well as learn.
#4 | |
Arslan Hasan
My purpose is to generate pressure or sound waves on the sensor and the sensor acts accordingly as described in the Figure 3. Thank you |
If you don't know which source you are providing, then you, most likely, are not providing any. Sensor will record or move due to pressure fluctuations, however, something has to cause those fluctuations. It could be due to fluid coming in and going out through a few boundaries or it could be movement of a wall.
#6 | |
Arslan Hasan
1. Select the Fluid Flow(Fluent) 2. In Geometry make a boundary around the sensor and apply a boolean (shown in the figure) 3. In Mesh, defined the inlet, outlet, and walls to the boundary and applied a mesh. 4. In solution, applied a boundary condition and select a pressure and calculated the result. I don't know whether I have performed the steps correctly or not. thank you |
Acoustics is just pressure fluctuations. You can either impose these pressure fluctuations in a quiescent fluid using a pressure wave or by modeling the flow using scale resolved simulations, such as, LES or at least using URANS. Somehow, you need fluctuations in the pressure field with time. I am not sure what you are doing right now; whether you have turbulence enabled or not and whether you are interested in a specific bandwidth or broadband. Modeling of a sensor is actually not required until and unless you are interested in modeling deformations of the sensor. If that is the requirement, then you will have to do FSI.
#8 | |
Regards, SJ |
acoustic, fluent |
acoustic analysis | polatovic | Main CFD Forum | 0 | October 21, 2015 09:01 |
analysis of multiphase and porous media in ansys fluent | ahmed_khatibs | FLUENT | 0 | November 4, 2014 12:01 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Turbulent Round Jet Fluent analysis | Renan Margonar | FLUENT | 3 | June 20, 2013 09:07 |
