Boundary condition causes MRF(steady) unconvergence |
March 3, 2020, 13:37 |
Rep Power: 6 |
Hello everyone,
I tried to simulate a pump piston motion which includes both rotation and translation, for rotation, I adopted the moving mesh method, and for translation, I took UDF method. In beginning, I wanted to use MRF to give a good initial condition for the simulation, however, once I ran the simulation, warnings came out: “Divergence detected in AMG solver: pressure correction.” And I found it is the outlet boundary condition (high pressure) that leads to this unconvergence, but I don’t know how to solve this problem, can someone do me a favor? Thx! Boundary condition: Inlet: pressure inlet 0 pascal Outlet: pressure outlet 35000000 pascal (35 MPa) |
March 3, 2020, 15:58 |
MRF and Initial Condition
A good initial condition is always useful as long as the system is continuous. However, in your case, MRF is not even applicable. You should initialize with 0 values for every field, except for Pressure and Dissipation Rate. For pressure, use a high pressure value. For Dissipation Rate, use a value of 1.0 or any positive value to ensure that is a realizable number. I am assuming you are using Ideal gas law. Therefore, temperature is another important condition, however, default value of 300 K will do equally well.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
fluent - udf, unconvergence |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
Accessing multiple boundary patches from a custom boundary condition file | ripudaman | OpenFOAM Programming & Development | 0 | October 22, 2014 19:34 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
