How to set up a 2D Taylor-Couette case in FLUENT?
Old   February 26, 2020, 08:47
Default How to set up a 2D Taylor-Couette case in FLUENT?
Magnus
Maggakahn is on a distinguished road
Hello fellow CFDers, I am quite new to FLUENT so any help would be greatly appreciated.
Problem description:
I want to study the classic Taylor-Couette problem consisting of an annular fluid domain encased by two concentric cylinders, where the inner most cylinder is rotating while the outer most cylinder is stationary. See the attached image for reference Taylor_vortecies.png.
As i want to study this problem using a 2D cross section of the concentric cylinders (z-r plane in the attatched image), I have encountered a problem with the boundary conditions for the rotating wall. I can not seem to find a way to give the rotating wall a speed in the theta (see attatch for ref) direction, i.e the normal direction of the crossectional 2D plane.
I have tried to use the Axissymmetric option in FLUENT, but since the axis of rotations placement differs from the rotational wall placement. For example if you had a 100mm inner cylinder, the axis of rotation would lie in the middle of that cylinder, while the rotational wall would be the wall of that cylinder. FLUENT does not seem to like if this is the case. For 2D pipe flows this is not a problem since the axis of rotation is in the middle of the pipe.
Thank you very much for reading. Any help is greatly appreciated!
Best regards,
Magnus
Maggakahn is offline   Reply With Quote
Old   February 27, 2020, 06:07
Default Taylor-Couette Flow
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The only requirement Fluent has with respect to 2D cases is that the mesh should be in its x-y plane. It cannot be in any parallel plane either. So, z must be 0. Now, for concentric cylinders, their center point could be located anywhere, say, (10, 13.5). But the axis of rotation can only be (0, 0, 1). Rotation could be CW or CCW. What you need to provide correctly is the center point. Then it will work as expected.
Second thing, not related to Fluent or simulation, is Taylor-Couette Flow. Except for very low Re, flow is 3D, so, you would miss most of the features of the flow in a 2D case.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 27, 2020, 06:59
Default Respond to Vinerm
Magnus
Thanks for the quick reply!
Problem is that the axis of rotation must also be either x or y in my case, since i want to simulate a 2D case for the r-z plane (See the image below for ref.)
Therefore i thought i would model it like this:
Where the line on the x axis is the axis of rotation and symmetry. And the rectangle above is the cross section of the cylinder, where the lower line is the moving cylinder wall.
Thank you again!
Old   February 27, 2020, 07:41
Default Three-Dimensional
vinerm's Avatar
Vinerm
That is not a possibility in 2D since the physics is no longer two-dimensional. Rotation around x-axis will make the case 3D because that would bring gradients in the \theta direction. So, the only viable solution is 3D.
Regards,
Vinerm
Old   March 5, 2020, 08:09
Default Any other possible methods?
Magnus
Thanks for clearifiying.
Do you have any suggestions on how to simulate this case without going to a full 3D case? The full 3D case will take a LOT of time to simulate, therefore it would be very helpfull to have a simpler case.
Thanks
Magnus
Old   March 5, 2020, 08:18
vinerm's Avatar
Vinerm
I doubt if anyone has ever modeled TC flow in two-dimensions. It certainly is doable but not in standard coordinates; this would require transformation to different coordinates. Refer the following
https://rd.springer.com/article/10.1...65542509040162
What I can suggest is to model it in 3D but keep axial dimension confined to one cell (TC cell and not mesh cell) and apply translational periodicity on end faces of the cylinders.
Regards,
Vinerm
boundary condition, rotating wall, taylor-couette
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
[Commercial meshers] OpenFoam Mesh to Fluent Mesh in parallel case DominicTNC OpenFOAM Meshing & Mesh Conversion 3 November 22, 2017 10:19
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Can't run a case in HelyxOS with an imported mesh from Fluent HHOS OpenFOAM Running, Solving & CFD 0 July 2, 2013 07:25
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 05:31
